17755
17755
błąd 17755 ktoś coś???
peacenotwar
http://wiki.ross-tech.com/wiki/index.ph ... 347/004935
Czyli masz problem z rozrządem lub g28/g163
17755/P1347/004935 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28): Incor. Correl.
Possible Causes
Timing Belt/Chain incorrectly installed
Timing Chain probably lengthened
Camshaft Position Sensor 2 (G163) faulty
Engine Speed Sensor (G28) faulty
Possible Solutions
Check Timing Belt/Chain installation
Use Measuring Value Blocks (MVB) to Check Timing Chain
Check/Replace Camshaft Position Sensor 2 (G163)
Check/Replace Engine Speed Sensor (G28)
Special Notes
When found in VR6 4 Valve (BDF, BJS, BAA,) engines in conjunction with 17748 please see Technical Bulletin 15-07-03. The previous Technical Bulletin number was 15-04-01.
When found in a 30-valve V6 gasoline Audi engine (such as EPB or BEL), DTC 17748 may be stored as well. If both of these codes are displayed simultaneously, and the codes only appear after the motor is revved above 1800RPM, then the issue is likely that the cam chain tensioners were installed on the incorrect heads (drivers' tensioner on passenger head, etc).
On engines with chain driven intake camshaft(s), but belt driven exhaust camshaft(s), verify the number of chain roller links between the intake and exhaust camshafts is correct. Click on thumbnail to enlarge:
peacenotwar
Powinna pomóc rozpiska ;) Czujniki na jedną i na drugą stronę mają rożne oznaczenia
http://forums.quattroworld.com/allroad/msgs/43292.phtml
peacenotwar
