Licznik RS4 do S4
bolo-s4
- Tytuł użytkownika: BOLO-S4
Licznik RS4 do S4
Czy ktoś ma w s4 lub wie jak podłączyć. Dwie kostki takie same ,środkowa inna ,nie sprawdzałem.
Tez nie problem :
Licznik po 1998 r.
connector for basic functions, 32-pin, blue
1 -Terminal 15
2 -Right turn signal
3 -Speedometer output 1
4 -not used
5 -Fuel gauge sender
6 -Airbag
7 -Terminal 31 (sensor earth)
8 -Coolant temperature
9 -Terminal 31 (load earth)
10 -Oil pressure switch
11 -Engine-speed signal
12 -Terminal 61
13 -Glow plug indicator or CAT
14 -Self-levelling suspension
15 -Terminal 58d
16 -Trailer turn signal/fault in engine electrical system
17 -Main beam
18 -Left turn signal
19 -ABS
20 -Terminal 58s
21 -Door contact, driver's side
22 -Low coolant level
23 -Terminal 30
24 -Terminal 31 (load earth)
25 -K wire
26 -Right parking light
27 -Left parking light
28 -Speedometer input
29 -Brake fluid level/pressure
30 -S-contact
31 -Belt buckle
32 -ESP
connector for additional functions, 32-pin, green
1 -not used
2 -Transponder 1
3 -not used
4 -Immobiliser
5 -W wire
6 -Boot lid/tailgate (Lowline version only)
7 -Brake pads (Highline version only)
8 -Input for outside buzzer actuation (currently vacant)
9 -Input for outside gong/chime actuation (currently vacant)
10 -Fuel tank warning output signal for engine control unit (6 cyl. TDI and USA vehicles only)
11 -Service life output
12 -Air conditioner shutoff
13 -Parking brake
14 -Electronic throttle
15 -Side marker light
16 -not used
17 -Transponder 2
18 -not used
19 -not used
20 -not used
21 -Oil temperature
22 -not used
23 -not used
24 -not used
25 -not used
26 -not used
27 -not used
28 -not used
29 -Terminal 58d (outside dimmer potentiometer)
30 -Speedometer output 2
31 -not used
32 -not used
connector for multi-function display 20-pin, red
1 -Consumption signal
2 -not used
3 -not used
4 -not used
5 -Ambient temperature
6 -Selector lever display
7 -not used
8 -not used
9 -Washer fluid
10 -Hydraulic system pressure
11 -On-board computer reset
12 -Clock signal for radio frequency display
13 -Data signal for radio frequency display
14 -On-board computer, left
15 -Enable signal for radio frequency display
16 -Tail lights/dipped beams (bulb monitor)
17 -Glow plug relay (diesel models only; low-voltage monitor in dash panel insert is disabled when glow plugs are operated)
18 -On-board computer, right
19 -Brake light
20 -not used
Licznik po 2000 r.
1 -Terminal 15
2 -Wear of brake pads
4 -not used
6 -Fuel gauge warning OBD 2
10 -Oil pressure 2 (high)
13 -Electronic throttle/ pre-glow control
15 -Terminal 58d
17 -Main beam
19 -not used
20 -Terminal 58s
23 -Terminal 30
25 -Consumption signal
29 -Brake
30 -S-contact
31 -Speedometer output 2
32 -ESP/TCS
1 -Door contact (all doors)
2 -Transponder 1
3 -not used
4 -not used
5 -W wire
6 -Tailgate
7 -Right turn signal
8 -External buzzer
9 -External gong
10 -Airbag
12 -Terminal 61
13 -Parking brake
14 -CHECK
15 -Oil level / temperature
16 -not used
17 -Transponder 2
18 -CAN high speed (drive) (high +)
19 -CAN high speed (drive) (low -)
20 -CAN high speed (drive) (screen)
21 -ABS
22 -CAN low speed (Convenience) (high +)
23 -CAN low speed (Convenience) (low -)
24 -CAN low speed (Convenience) (screen)
25 -Bonnet
26 -not used
27 -Belt buckle
28 -K wire
29 -Ambient temperature input
30 -not used
31 -Selection range
32 -not used
connector for multifunction display, 32-pin, grey
1 -Switch menu guide (menu)
2 -Switch menu guide (out A)
3 -Switch menu guide (out B)
4 -Switch menu guide (Enter)
5 -CAN high speed Display (high +)
6 -CAN high speed Display (low -)
7 -CAN high speed Display (screen)
8 -Door contact, passenger side
9 -Door contact, rear right
10 -Door contact, rear left
11 -Enable
12 -Clock
13 -Data
14 -Brake light
15 -Washer fluid level
17 -On-board computer, left
19 -On-board computer reset
20 -not used
21 -not used
22 -not used
23 -Key branch 1 Navigation system
24 -Key branch 2 Navigation system
25 -Key branch Telematics
26 -not used
27 -not used
28 -not used
29 -not used
30 -not used
31 -not used
32 -not used
connector for radio clock, 4-pin, black
1 -Radio clock signal (data)
2 -Radio clock 5V
3 -not used
4 -Radio clock earth
Licznik po 1998 r.
1 -Terminal 15
4 -not used
6 -Airbag
12 -Terminal 61
15 -Terminal 58d
17 -Main beam
19 -ABS
20 -Terminal 58s
23 -Terminal 30
25 -K wire
30 -S-contact
31 -Belt buckle
32 -ESP
1 -not used
2 -Transponder 1
3 -not used
4 -Immobiliser
5 -W wire
13 -Parking brake
16 -not used
17 -Transponder 2
18 -not used
19 -not used
20 -not used
21 -Oil temperature
22 -not used
23 -not used
24 -not used
25 -not used
26 -not used
27 -not used
28 -not used
31 -not used
32 -not used
2 -not used
3 -not used
4 -not used
7 -not used
8 -not used
9 -Washer fluid
19 -Brake light
20 -not used
Licznik po 2000 r.
1 -Terminal 15
4 -not used
15 -Terminal 58d
17 -Main beam
19 -not used
20 -Terminal 58s
23 -Terminal 30
29 -Brake
30 -S-contact
32 -ESP/TCS
2 -Transponder 1
3 -not used
4 -not used
5 -W wire
6 -Tailgate
8 -External buzzer
9 -External gong
10 -Airbag
12 -Terminal 61
13 -Parking brake
14 -CHECK
16 -not used
17 -Transponder 2
21 -ABS
25 -Bonnet
26 -not used
27 -Belt buckle
28 -K wire
30 -not used
31 -Selection range
32 -not used
11 -Enable
12 -Clock
13 -Data
14 -Brake light
20 -not used
21 -not used
22 -not used
26 -not used
27 -not used
28 -not used
29 -not used
30 -not used
31 -not used
32 -not used
2 -Radio clock 5V
3 -not used
